It is currently Sat Aug 23, 2025 6:15 am
PostPosted: Thu Jul 04, 2013 8:16 am
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
Looking for ideas, suggestions on burst recipes...i.e. tints used, order of spraying colors, ...gun setting for toning...etc
I have done a couple and never seem to be quite satisfied .....
I will be using em 1000 for mixing and spraying the colors followed of course by em 6000
Currently I use a small .06mm gun for sraying bursts which gives me good control over settings and patterns
Happy 4th!!!!!!!! bliss bliss bliss Eat Drink Eat Drink
MK5acoustics.com
PostPosted: Fri Jul 05, 2013 11:27 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I use solar-Lux to tint my shaders. The base color is a custom mix of yellow and red mahogany, the outer is typically either hickory or red mahogany, depending. You would need to check that these are compatible with your finish as I use nitro.
Brian
PostPosted: Fri Jul 05, 2013 8:38 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
what size gun are you using for the to shoot the tint,,,,what kind of pressures????
MK5acoustics.com
PostPosted: Fri Jul 05, 2013 9:20 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
good point...I have done a couple of practice tops...using amber , red and brown...both using em 1000....
one shot amber followed by the outer brown then shaded with the red....worked good but the brown came out a little too reddish for the bubinga back and sides
the next one I shot amber then red then brown ...
pressures have been between 22 and 40 using a small harbor freight touch up gun with a .6mm nozzle...I like this little gun, it shoots a very good spray pattern that is easy to control...
I am just looking for some advise on colors, spray control, tint mixing, expecially with em 1000 as the color vehicle..... etc.
here a a couple of pics the om style top has the red over brown , the other brown over red...plus I added a couple drops of black to darken the red..
please critique and don't hold back!!!!
fyiu both of these are tops that got screwed up for one reason or another...
MK5acoustics.com
PostPosted: Sat Jul 06, 2013 5:37 am
Last Name: Howard
City: Magnolia
State: Delaware
Both look a little fender tri tone for my taste on an acoustic. When fender did the tri tones they dyed the wood yellow, sealed, shot the red and then the dark brown and then clear. I generally only put down a background color and then shoot the burst with one toner. One key to a good burst is level sanding between colors. The sealer should be perfectly level before the first toner and then each toner should be level sanded before the next. Otherwise the surface texture will tend to make your colors look a bit uneven and can lead to problems sanding through to the toners when you buff. My gun set up will not be much use to you as I use a gun with pattern control so I can tighten up the pattern and choke the air and fluid as needed to match. I do everything with that gun, I believe it is set up with either a 1.2 or a 1.4 needle and tip but I would need to take it down and look to be sure. What you want is very good flow out when you lay down the toners. It takes a bit of practice and like so many other things there are a lot of ways it can be done, finding the one that works for you and your material/equipment will take some experimentation and practice.
Brian
PostPosted: Sat Jul 06, 2013 6:50 am
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
Good looking bursts. I'll bet they look even better in person. I was not confident in my ability to keep the pattern even without one, so I made a wheel.Image
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Sat Jul 06, 2013 10:04 am
You might also pic up Stewmac's sunburst DVD by Don McRostie. Got mine many moons ago on VHS....it's pretty good on mixing/matching/spraying & I see they've got it on "closeout" special (.....lots of other deals there as well)
http://www.stewmac.com/closeouts.html?u ... B_20130705
Milton, ON
PostPosted: Sun Jul 07, 2013 8:12 am
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Looks great..what are you approx. mixing proportions???
I have also decided to invest in a new gun and trash all the cheap stuff I have collected over the years... I recently upgraded to a newer compressor..
any reccomendations on guns....HVLP for compressor obviously....
MK5acoustics.com
PostPosted: Sun Jul 07, 2013 12:23 pm
First name: Greg
Last Name: B
City: Los Angeles
I've never tried a burst, but if I did I'd watch this excellent tutorial a few times first:
https://www.youtube.com/watch?v=HQY1yMzdQC4
PostPosted: Sun Jul 07, 2013 1:13 pm
Last Name: Sonksen
City: PORTLAND
State: Oregon
Zip/Postal Code: 97216-2013
I'm a little confused as to why HVLP seems to be the standard gun for most people around here. For lacquers that will be cut back after being sprayed I understand, you can get a lot of material on the body and don't need to worry about how well it lays out, but one of the big knocks on HVLP has always been coarser atomization. There are things you can do to compensate for this and no doubt they are efficient for getting the most material onto the surface as possible as long as you use the right pressure
I think in order to get the better atomization with an HVLP though you have to boost the air pressure on a siphon feed or gravity feed, or increase the air and cup pressure on an air assist, siphon feed which defeats the efficiency of the HVLP. For doing bursts and toning I much prefer a conventional gun or what's called a compliant, which is somewhere in between an hvlp and a conventional. I use a compliant devilbiss at work and I love that thing. It gives me beautiful atomization with a 1.4 mm needle and also allows me to turn the pressure way down to get into tricky areas and spray piss coats of light material without worrying about runs.
If I were spending my money on a gun I would look at the CA technologies compliant gravity feed. They have 3 needle nozzle sets, are compatible with PPS and are about the same price as the gun I use at work by devilbiss. Here's a link http://www.spraycat.com/compliant.html
as far as your other questions I would say if you don't like the red you can add more black which will cut the brightness or you can just get rid of it all together. If you are spraying amber first and then red you will actually have the red turn orange slightly which could easily clash with the bubinga if the colors are off from one another. I think transtint makes a red brown that you could try instead of the straight red which may help, although you should be able to make that yourself out of red and brown. As far as concentrations go I like to mix my colors so they will spray out to final color in two passes and then add twice as much medium (lacquer, lacquer thinner, etc) to the mix as what I made the original color with. That way it will take about 6 passes to get to the color you want. This helps with blending color because if it's too concentrated you'll end up just spraying hard stripes. One other thing is I like to spray the dark edge first and then the lighter colors. It's easier to see how far in you want to bring the lighter colors from the edge that way and by doing that you also give yourself an easier reference point by essentially bringing the outside edge in closer the subsequent lighter colors.
I don't think anyone can offer advice on pressures without having their hands on the exact gun you're using, how much volume you are trying to spray and what your fan size is. Narrower fans and thinner material require less air to atomize so it's very subjective. Just run some test pieces and adjust it until it looks right.
I also find it easier to spray with my parts on a horizontal turntable than an upright wheel. It's more natural for me to hold the gun over the middle of the body and turn the body underneath moving the gun in an arc to follow the curves than it is for me to try and do that upright. The only caveat though is you do not want to do that with cheaper guns that might leak. One drop and your toast, which I learned very much the hard way with a cheap harbor freight airbrush.
PostPosted: Sun Jul 07, 2013 7:47 pm
First name: Kenneth
Last Name: Casper
City: Northville
Country: U.S.A
Hi Wes,
I've done quite a few bursts using Target products. In fact, three of my last four commissions were all bursts. I like the transtint dyes, laying down a couple of coats of EM6000 tinted with honey amber. Note at this point, my tops look very yellow. But under 10 to 12 coats of clear, the yellow edge is gone and the top takes on a wicked yellow/amber glow that goes off like a bomb in good lighting. When I shoot my bursts, I add browns, typically dark mission brown to EM1000 then shoot it so it goes on almost dry. I have my piece laying flat and slowly work my way around the perimeter, adding color to get the transition I want. I then add black to the same mixture and work from the perimeter edge in until I have a nice transition.
Note that my process results in visible speckling in my bursts. My customers have said they prefer that look, so I have made no attempt to minimize them. Below are a few pictures of one of my typical bursts, the last one actually on a ziricote OM.
Ken
http://www.casperguitar.com
PostPosted: Mon Jul 08, 2013 7:55 am
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Todd you mentioned a fx1000 in a previous thread, did that gun work good for you??
MK5acoustics.com
PostPosted: Mon Jul 08, 2013 11:44 am
First name: Kenneth
Last Name: Casper
City: Northville
Country: U.S.A
Thanks Todd. The key for me is not so much the gun but the technique. I am shooting those bursts with a very nice Asturo Eco S HVLP, the same one I lay down lacquer top coats with. I drop the pressure so the atomization is a little rough, and I shoot the finish so it goes on practically dry. There is no film flow on the surface. I also dial in a somewhat narrow spray pattern, and I hold the gun away from the permeter and up, so the color is hitting the top at an angle. In other words, as I am spraying the top, I am also spraying tinted lacquer along the masked rims of the guitar. This difusses the lacquer a bit more around the center while keeping the perimeter dark.
I'm sure there are a lot of successfull ways to shoot a burst, with each style being unique. I shoot what appeals to me, and though I could get a much finer transition if I wanted, the vintage vibe has been very popular, and specifically requested on my last two bursts.
Ken
Todd Stock wrote:
I think that grainy burst look is very retro/vintage...I see it on the 50's low end stuff from Harmony and Kay and some of the Kalamazoo and other B-stock Gibson lines. Keep in mind that lacquer or shellac sprayed bursts were trying to emulate the wet-in-wet look of earlier hand-burst instruments, and on low-end stuff, that coarse/grainy burst is a very good match for the original appearance. The very slick, almost machine-like blend on higher-end stuff from Fender. Gibson, Martin, etc. is a little sterile compared to the splits and sputters seen in some of the older bursted instruments coming out of Sears or other mail-order vendors. I've had to do this sort of grainy/sputtery burst on repair touch-up work, and it is a challenge ... bravo to Ken for figuring out how to emulate these unique finishes with such fidelity.
Filippo - will have to try the spray bomb approach - never have been able to get the Fuji or the SATA guns to spray that pattern with consistency...thinking a Harbor Freight gun might be worth trying out to see if it can be tuned to give that effect...I have a Kalamazoo in that will need touchups, and the burst is very similar to Ken's work.
PostPosted: Mon Jul 08, 2013 12:27 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Ken what size tip are you using ?
MK5acoustics.com
PostPosted: Mon Jul 08, 2013 8:03 pm
Last Name: Sonksen
City: PORTLAND
State: Oregon
Quote:
I have not seen any issues with modern HVLP guns from higher end companies...the SATA and Iwata guns seems to have no issue atomizing lacquers or clears, and the Fuji guns (XPC and the new T-75G) are better than the conversion guns I've used. I think the atomization arument was valid for guns with tip pressures in the 6 psi range spraying thicker materials, but four stage turbines generate 8 to 8-1/2 psi at the tim and modern air cap designs seem to do a good job with just about any finish we are likely to shoot. FWIW, I spray Mohawk unthinned and don;t see atomization issues on either gun...even with my older 3 stage Turbinaire dialed down a bit.
I don't make jokes. I just watch the government and report the facts.
– Will Rogers
Thanks for the response Todd, I don't have any experience with turbine systems so I guess this stuff is a bit over my head. I have been scratching and clawing my way into this century with the equipment at my shop and have been pretty impressed with the advancements just in the last ten years.
Out of curiosity is there a big advantage to using turbines vs air? I've mostly seen turbines for use in portable situations, but it sounds like a lot of people around here prefer them. Is it simply a matter of space or does it help with efficiency? I've looked at the Fuji systems but because I have access to a full spray booth at my shop I haven't been too concerned with setting up my own spray system/setup. Would be good to know for future reference.
Thank you for the specific answer, out of curiosity do you have any experience with or opinion of the CA Tech guns? I've heard good things but mostly from people who are trying to sell them...
PostPosted: Tue Jul 09, 2013 9:35 am
Last Name: Sollod
Is it necessary to level sand between color coats? ...or spray each color coat, then coats of clear before level sanding...?
www.swiftcreekguitars.com
PostPosted: Tue Jul 09, 2013 10:07 am
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
I do not sand until after the top coats.
PostPosted: Tue Jul 09, 2013 6:52 pm
First name: Kenneth
Last Name: Casper
City: Northville
Country: U.S.A
1.3mm
PostPosted: Wed Jul 10, 2013 7:14 am
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Thanks , I ordered a sharpe fx 1000 with a 1.4 mm tip...
MK5acoustics.com
PostPosted: Sun Jul 14, 2013 7:25 am
First name: David
Last Name: Radlin
City: Belle River
Zip/Postal Code: N0R 1A0
On recommendation from my supplier, I forgo the use of EM1000 sealer and shoot all my colour coats with tinted EM6000. That has been successful for me...
David Radlin
http://www.facebook.com/radlin.guitars
PostPosted: Sun Jul 21, 2013 8:10 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Using a quality gun makes all the difference..here is a good video for those who haven't seen it
http://www.youtube.com/watch?v=VJNnAw-rXng
I followed this sequence using very light coats gradually building the brown first followed by amber then red....lightly scuffing the center between the brown coats to remove over spray...not the best of pictures though..
MK5acoustics.com
PostPosted: Mon Jul 22, 2013 9:56 pm
First name: Kenneth
Last Name: Casper
City: Northville
Country: U.S.A
Looking good, Wes! Glad you found a process that works! One of my current commissions just signed up for a burst, so looks like I will be shooting another later this year.
Ken
PostPosted: Mon Jul 22, 2013 10:07 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
The two cutaways are commission builds, and he wanted bursts..the L-00 is one I built a couple of years ago, I didn't like the finish so I sanded it down to the wood and used it for practice...
MK5acoustics.com
